If I have an Arial or several other fonts defined in a 24"x 36"drawing. When I zoom extents, it adds several inchs of dead space to the top of the drawing view (nothing on hidden layers). Same if I plot the drawing by extents. If I set all styles back to txt zoom and plot extents works fine. Any suggestion other than making all fonts txt.shx
@Anonymous wrote:
I had attached one to my last reply.
Did you have another method in mind.
It appears that reply was via email. I believe you have to attach files while using a browser to view the discussion forums.
I have attached a scrubbed dwg and a png file
The png file is of the plot preview and it was set for extents and there were no hidden layers.
They are empty text, they are there but can't be seen.
There are autolisp and tricks to delete them
They are empty text strings.
They can be seen if you zoom e and then zoom back a bit.
They can be deleted in the BE (cause they are embedded in the TB) by turning on QTEXT and selecting/deleting them.
DJ
PS: Don't forget to turn QTEXT off or all your text will be rectangles of the bounding box of the text
PPS: A regen is required after the QTEXT setting
