I am working on a 3d house. I have created the doorways and window spaces using presspull. Now, weeks later, 4 windows have been replaced by 3 and a double door has been changed to a single. I cannot figure out how to narrow or remove the doorway or how to remove one window and re-center the other three. I am a newbie at 3d but it would seem there should be a way to make adjustments. Any ideas? Thanks!
Oh, yes - Autocad 2014 for Mac
Solved by nestly2. Go to Solution.
On the Ribbon Solid Editing panel, there are tools for Move Faces, Offset Faces, and Delete Faces, however you can also just use CTRL+Click to select Faces/Edges and edit them with Grips either by dragging, or entering a displacement value. Use CTRL+Click to select adjacent faces in a door or window opening and ERASE command will remove the opening. CTRL+Click parallel faces in a door or window and you can move the opening.
(I'm a Windows user, so I can't verify that it works exactly the same in Mac)
Search the Help files or Youtube for SubObject Selection for more information.
Thank you so much! It took forever to find my post so I was flying blind while only reading the email notification. I did want to thank you, so I searched for the post and finally found it along with the video. That made it so much easier! By the way, CTRL+Click worked on Mac the same way. If you know how to find posts easily, I wouldn't mind a heads up.
I have more questions but I think I have to create new posts for each, right?
Thanks again.
Sorry about that, I had not considered that my message may not be very clear without the video.
The link in the email should bring you directly to your topic. Also when you're logged in, click on the green "My Toolbox" area along the right side. The section called "My Subscriptions should hold the three most recent topics you've posted messages in.
If related to the original question, it's fine to ask additonal questions in the same topic, but if it's a different subject, just start a new topic. General AutoCAD question such as this one are fine to post here, but anything that's Mac related should probably go in the AutoCAD for Mac forum.
