Hello all,
I have reviewed nearly 100 posts in multiple forums, pertaining to this topic and have not found a single solution to my problem.
When I attempt to copy and paste in my drawing, it slowly saves the drawing once I specify a base point then will paste absolutely nothing.
I was recieving the Sketchbook Designer error until I uninstalled Sketchbook designer. That message no longer appears, but I still cannot copy and paste in the drawing.
Occasionally in the sequence it references simplex.shx files.
I am also recieving a message: Duplicate Definition of block_Archtick ignored?
Measures taken to solve this problem:
Uninstalled Sketchbook Designer
Changed FIRSTPICK from 0 to 1
Command STYLE and changed all referenced fonts to a Country Blueprint which is an Autocad font
Cleared all Layer filters from the drawing
Attempted to delete linetypes that clearly came from the initial file I recieved, but it will not let me delete any of the linetypes
If you have any ideas they are much appreciated. Each post I have read never gives a solution just a reference to another related topic.
Eric
