Hi all,...
Important Issu I think,...
All block containing Circle, Spline or Ellipse have Linetype Reset when they are scaled in a drawing who contain more that 1 ViewPort. (tested with CAD 2010 -> 2014)
any one else had or have this issue ?
Have you tried REGENALL to update the viewports?
I meant no disrespect. I usually recommend the simplest solution first, then work up from there.
This is what I found by experimenting a little further:
I made several non-annotative blocks using different units. e.g. Unitless, Inches, Millimeters, Feet.
I then made the same blocks only this time annotative.
I made several viewports with these scales in paperspace. 1:1, 1:12, 1:10, 1:50, 1:100, 1:48
After REGENALL these were my results: (top four different sized blocks are non-annotative in the order left to right: Unitless, Inches, Millimeters, Feet. bottom four equal sized blocks are annotative same units as above)
All the blocks which were non-annotative exhibited your results. All the blocks which were annotative previewed normal in every viewport. One difference was the annotative blocks were not big enough in the largers scales to show true linetype. i.e. the 1:48, 1:50 & 1:100
If I adjusted the linetypescale for the larger scales or made larger objects they showed fine.
Now this is where it gets interesting. I published my paperspace to create .pdf and convert to .png. All lines plotted as desired, in every block! Even though in the .dwg they exhibited your same characteristics which started this topic.
See attached results from screen shot of paperspace and actual published results.
It is in any drawing... you can create new one, with new Blocks set linetype by block, then, Insert ans scla the block...then,,,create a simple viewport and adjust your settings to see the Linetype effect correctly...
Once done,..create a new ViewPort beside the first one....and REGENALL. you will see the chage of the first ViewPort.
but, for quicker step....attached a drawing made from acad.dwt...
in this drawing...a simple block made Linetype by block containing circle..
you will see only 1 viewport.
Now,...open this drawing and create a new viewport beside the one on this drawing...
and regenALL...
you will see the circle entity turn into continuous linetype.
this affect also splines and ellipses.
(DWG = saved in 2010 format.)
I think this behavior is in all drawings. It is a bug, as you first indicated. I really believe as long as the user's plotted results are correct, teh developers at ADesk will not lose sleep. They will simply resign it to the "known issue" pile. Something to fix and then rave about as a "new" feature in 2016. 🙂
I'm glad I could help verify your findings. My version is 2012 so it has been ongoing.
Like I said, can't replicate here (and your file contained a custom linetype, you see good old DASHED and DASHED2 here):
Hi, following your steps I was able to get your results, but if I clicked into model space in the viewport and did a REGEN, the linetype showed correctly. I had to do that for both viewports. I do have a lower end video card so maybe that is the problem?
I remoted in and tested your file, Full AutoCAD 2012 and 2014, no issues. Screenshots attached.
I'm not sure what else to try to replicate your issue.
