OK, I am in need of a proxy enabler for different software. I am opening up several drawings and each one of them have a differnet issue with proxies, type files one is from the Bentley company and the other one I have no idea what program it form but I do know that the dialog box is give me this info ARLCShipCon and ARLCLable Class if anyone know what program this is it would help. And let me know if there is enabler for both of them.
AutoCAD 2013 (64bit)
Bentley produces a lot of different software; you will need to know which in order to download and install the correct object enabler.
Note that installing object enablers isn't always necessary. If you want to view drawing elements then it needs to be installed; if this is just to dismiss a warning dialog and the drawing isn't missing any content, then you can look into ways to remove the offending data or disable the warning dialog.
The Proxy Information box will show what the missing application is, and hopefully enough information to contact the publisher. Bentley support is fairly reasonable, they may need you to send a copy of the file so they can see what is needed. You should also ask those who created the file as they should know what software and version was used along with which OEs you will need. You might end up needing the full version of the applicable programs to do work with those files.
The tricky part is this: all entities (lines, circles, 3D solids, etc.) are objects, but not all objects are entities. So you may be getting a warning because there is data embedded in the file which has zero impact on what you are doing. For example, if I open a simple drawing with Bentley AutoPLANT but do nothing other than save it will add data to the drawing. When that drawing is opened elsewhere on a computer without AutoPLANT or the object enabler it will indicate "Missing application: blahblahblah" even though it won't affect the drawing.
You're up against a corner, I'm afraid. You *really* need to get ahold of the originator of the drawings so you know what you are working with, since you may need to purchase that software to work properly with the files.
OK I just found out the program or add-on they organator used or using its Ship construction any idea or info on this program
