A drafter in my office has been experiencing a problem with AutoCAD 2013. When she clicks on the "New" button, it acts exactly the same as the "Open" button. She is unable to open a new drawing without opening a new instance of AutoCAD.
Has anyone experienced this? If so, how do you fix it? I would rather not do a complete re-install if I can avoid it.
As always, any and all help is sincerely appreciated.
Solved by jggerth. Go to Solution.
Short of a re-install, you can do a Repair from Control Panel. Or pick the "Reset Settings to Default" from the Start menu...
If instead of clicking one of the many icon/menu items tio create a new drawing --
What happens if the user types in NEW at the command line?
What happens when QNEW is typed in?
Thanks to all of you for the replies.
This was a new install for a new employee (which I should have mentioned originally). Unfortunately, the employee did the repair from the control panel before I was able to grab screen shots...........
If it happens again, I will definitely have her stop what she is doing and get screenshots.
Thank you all again.
