AutoCAD Forum
ISO CIRCLE
6 REPLIES 6
1147 Views, 6 Replies
ISO CIRCLE
How can you rotate an iso circle F5 doesn't seem to work in 2013?
thanks
6 REPLIES 6
JDMather
Have you activated the iso grid?
Kent1Cooper
Or, SNAP command, Style option.
Or, (setvar 'snapstyl 1)
Kent Cooper, AIA
in reply to: Kent1Cooper
HI and thanks for the responce. I already have it set for isometric snap, I just can't get it to rotate to the position I want. F5 key doen't do anything.
Kent1Cooper
Ah, the isometric surface you want to draw on....  That's the SNAPISOPAIR System Variable.  With three values [0, 1, 2], here's one way to cycle around them:
(setvar 'snapisopair (rem (1+ (getvar 'snapisopair)) 3))
Kent Cooper, AIA
hgasty1001
With Ctrl+E you can change the view(front-top-side) of the isocircle.
Gaston Nunez
Thanks I'm use to f5
Forma Design Contest
