Has anyone discovered a way to import multiple files in one batch. We are currently using the import commandto bring in FBX files as blocks.It would be great to automate this process and allow multiple selection. Icing on the cake is assigning automagically to layers based on the name of the FBX file being brought in.
-David S. Perkins
I just attempted, unfortunately it does not work. I tried dragging multiple fbx's into an open drawing's model space, as well as the design center window.
Dragging multiple DWG's opens them in seperate tabs. Thanks for the idea though!
You could try writing a script that you can run inside of AutoCAD to import the files. I don't have any fbx files to try this with so I don't know the exact steps that you would need. You would have to turn off FILEDIA to do this so your script would start with:
(setvar "filedia" 0)
(command "import" "filename" ..... ) don't know the exact steps - an enter is double quotes ""
(setvar "filedia" 1)
Hope this helps
That would work if I need to import the same FBX files each time. The time it would take to edit this script for each use is about the same as importing each by hand one at a time. Is there a way I can add this as a feature request to allow multiple selection in the import window. I'm sure other users would benefit from batch importing.
Here is a link for providing Autodesk with suggestions for improvements to the software.
This is a small utility tool developed with AutoLisp which import drawings files of different types in to AutoCAD and create drawing files in the folder. No matter how the directory structure is, it will still import all the files and move the original files to a sub-folder. In the upcoming videos, we will see more in importing descriptively in to AutoCAD.
AutoCAD 2018 supports these format files,
("*.ste" "*.stp" "*.step" ".dxf" "*.iges" "*.igs" "*.fbx" "*.sat" "*.ipt" "*.iam" "*.model" "*.session" "*.CATProduct" "*.dgn" "*.ij" "*.prt" "*.asm*" "*.3dm" "*.sldprt" "*.asm" "*.sldasm" "*.g" "*.x_b" "*.x_t" )
More on this https://www.gsunitedtechnologies.com/cad/stepimport/?referer=forums-autodesk
Import CAD format files recursively to AutoCAD - Visual Lisp
Your supplied code at the web page link is non-functional.
All that happens when running the code is an error;
Command: SFIMPORT
; error: no function definition: ALE_BROWSEFORFOLDER
Does someone out there have a function that actually works?
Here's the non-functioning code from the provided link;
(defun c:sfimport() (setq path (ale_browseforfolder "Select directory to get files:")) (setq ftype "*.step") (setq flist (getfolders path ftype T)) ; change nil to T to get sub folders (alert "\n\n Click OK to continue SFImport..") (stepImportRecursive flist) (princ) )
The only problem is the stepImportRecursive command I couldn't replicate as the website is not inactive however this is what I came up with as I have over 1000 step files to reproduce for Plant 3D HDPE parts
(defun c:sfimport(/ ALE_BrowseForFolder path ftype flist fname GetFolders extensiontype )
;; Original BrowseForFolder by Tony Tanzillo
(defun ALE_BrowseForFolder (PrmStr / ShlObj Folder FldObj OutVal)
(vl-load-com)
(setq
ShlObj (vla-getInterfaceObject
(vlax-get-acad-object)
"Shell.Application"
Folder (vlax-invoke-method ShlObj 'BrowseForFolder 0 PrmStr 0)
(vlax-release-object ShlObj)
(if Folder
(progn
(setq
FldObj (vlax-get-property Folder 'Self)
OutVal (vlax-get-property FldObj 'Path)
(vlax-release-object Folder)
(vlax-release-object FldObj)
OutVal
(defun GetFolders (path / l c)
(if (setq l (vl-directory-files path nil -1))
(apply 'append (mapcar
(function (lambda (x) (cons (setq c (strcat path "\\" x)) (GetFolders c))))
(vl-remove "." (vl-remove ".." l))
(setq extensiontype ".step")
(setq ftype (vl-directory-files path "*" extensiontype ))
(setq flist (getfolders path)); get sub folders
;;; build your own stepImportRecursive
(foreach 3DModel ftype
(command "_import" (strcat path "\\" 3DModel) )
(setq fname (substr 3DModel 1 (- (strlen 3DModel) (+ ((strlen extensiontype) 1)))))
;;;export imported blockname possible wblock???
;;; end stepImportRecursive
(princ)
I can only assume that it would use flist and for each directory actually use (setq ftype (vl-directory-files path "*.step"))
the above works at the moment
