Is it possible to lock the location of a point cloud without disabling the ablity to use the cropping functions in AutoCAD 2015? With the point cloud unlocked I keep inadvertently moving it somehow.
Solved by christina.davis. Go to Solution.
Hi Brian,
If the point cloud is locked (even on a locked layer) the cropping functions won't work, but you can switch back and forth between locked and unlocked through the Properties palette (see attached image). Pick the point cloud, set Locked to No, crop, and then set Lock back to Yes.
I hope that helps.
With the Point Cloud Cropping Tools plugin it is possible to crop locked point clouds.
