I have an .ECW file with associated world file .ERS (for georeferencing) and I would insert it into AutoCAD. You can understand that this file hasn't embedded positioning informations. These informations are located into the .ERS file.
I know that AutoCAD since 2012 natively supports files .ECW, While up to version AutoCAD 2011 you had to install the Raster Design 2011 Object Enabler to view ECW files.
Now I tried to attach the file .ECW using the commands insert--> external references --> attach image , but AutoCAD asks to me scale factor and insertion point. This is the problem, the image is not georeferenced, is like AutoCAD doesn't read the associated file .ERS. The image is inserted on the origin of axis (0,0,0). -See the screenshot-
I Know that exists "GeoRefImg" add-on and I installed it, but it doesn't work with the .ERS format. Using the GEOREFIMG command it responds saying "FILE NOT FOUND". This add-on works good georeferencing with world file .EWW format.
Now the question is, how can I import my file .ECW whit his associated .ERS world file on AutoCAD, maintaining the correct georeference ??
AutoCAD Map should be able to do this. I'll be watching this thread to see if plain vanilla AutoCAD can. Unfortunately, I'm not sure, but I'm guessing not since there are 3rd party tools for this:
http://apps.exchange.autodesk.com/ACD/en/Detail/Index?id=appstore.exchange.autodesk.com%3aGeoRefImg%...
Read my precedent post please. I have alredy installed GeoRefImg, but it doesn't work with .ERS world file extension.
Thank you for your kindness, but you do not help me. AutoCAD is not good for this, I will try AutoCADMap.
I have the same problem with Map2013, and I have it with all georeferenced formats. Cad simply doesn't read data from second file.
Any answers?
With Autocad Map3D the correct command is Mapiinsert if you want it to be geo-referenced and scaled correctly.
Hi @Anonymous,
I don't believe this functionality is available in native AutoCAD. I suggest you contact the manufacturer of that add-in to see what they say?
Normally I would suggest that this operation would be best performed in AutoCAD Map.
What coordinate system(s) are involved?
The coordinates are in Croatia's system Cropos and I've put files to see. On my buddies PC it works normally with those files and many others like that. The .txt file is actually .jgw but I had to change extension cause I can't upload here jgw.
I've just find out that it imports georeferenced image, but ONLY .tif format. I was playing with Quantum and exporting image in many formats to try it out with cad, and, as I found out, my MAP will import only .tif. Why only that, I can't tell.
If it worked in your buddies computer and not in yours then try a repair of your Map3D, sounds like you have a corrupt install. Also you may want to post the questions in the Map3D Forum to get more replies.
GeoRefImg supports only the standard georeference world files - i.e. .EWW world files in case of .ECW images (no XML, no ECW-specific formats)
Vladimir Michl, www.cadstudio.cz www.cadforum.cz
