Hi, one of my customer asked for a "plugin" that exist in version 2010 of Autocad.
It's the “dimension finder” tool, and now they are using the version 2014. Someone know if this script exist for the version 2014 or something that replace it, or something new built-in?
Heres a link to the 2010 version with explanations: http://through-the-interface.typepad.com/through_the_interface/2010/03/using-overrules-to-highlight-...
Thanks!
Solved by pendean. Go to Solution.
Solved by dmfrazier. Go to Solution.
If you go to the Customization board (http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/bd-p/130) and search on "find overridden dimensions", you will definitely find a LISP routine that will do what you appear to be describing.
Here is a link to one in particular that I recall seeing recently:
There's also this:
