We are facing strange issue with all different versions of AutoCAD (2007, 2011, 2013). While users are working on the file, all of a sudden the contents (work done) are lost and it becomes all blank. The file size is same but when we open the file all the work done is not displayed, but just a blank screen.
It happens occasionally and there is some Automation Error in the command line below. The software is not hanging but the open file is in hang state and we have to close it. While closing whether we select yes/no the content (work done) is all lost. The temp location where the files are saved in one of the computer is become huge around 40GB will many Autocad autosave and temporary files; if it has anything to do with it !
Can anyone guide what could be the possible issue ?
Reading this entire thread, it would seem that this error is generally caused by a virus, one that relies on creating and loading an acad.fas file.
If a file with that name exists anywhere on the machine or network, then that prima facie evidence of a virus / malware attack.
And to re-iterate Dean's comment 'yesterday's backup, the day before's backup'
Hi the file with the back file attached.as I open the cad two kind file name,name dwl and dwl2 atomaticaly open,the most important is that there is third file atomaticly created which name is alway cade,i used anit viru but no any advantage the same happening agin and agin.
DWL and DWL2 files have nothing to do with this problem. They are simple text files used by the WhoHas function in AutoCAD.
(They have nothing to do with file locking either BTW)
I just started getting the following error in my AutoCAD 2015:
"Error querying data: Automation error. Operation is not allowed when the object is closed"
I was not in the middle of any commands. It only happens in certain drawings when I try to save. I cannot save at all! Not SAVE or even SAVE AS, nothing. Can anyone tell me how to fix please? Already tried purge and audit, no good.
I had this problem last week and search and try all possible solution even reinstall AutoCAD and format my PC.
This is simply a virus within our computer and even running antivirus, it cannot detect it. Now, I just turn OFF / UNCHECK
this two options in autocad and SOLVED MY PROBLEM.
1. UNCHECK THE AUTOMATIC SAVE
2. UNCHECK THE CREATE BACKUP COPY.....
Its very easy and effective. try it and let me know if this working
ALI
draftsman
