Dear all,
I have the Building design suite ulltimate 2014 installed on my PC (Windows 7 64 bits.)
Since version 2013 and till now the open preview is not shown ( See the picture attached)
Is there a final solution for this problem?
Thank you.
Wassim
Solved by nestly2. Go to Solution.
Try this
Dear Sir,
Thank you for your support,
I have checked the registry key as you mention but all the variable are set to 1.
When I have installed first the building suite ultimate the preview is normal but now nothing is shown.
This is happened also in the version of 2013.
When I reset the profiles in the Option menu of Autocad the preview return but all my setting (Cursor, background are reset also). I do not know how to resolve this problem.
Your help is very appreciated.
Thank you
Wassim
@Anonymous wrote:When I reset the profiles in the Option menu of Autocad the preview return but all my setting (Cursor, background are reset also). I do not know how to resolve this problem.
Soluton #1) Adjust the Cursor, background etc in the "reset" profile
Solution #2) Adjust the Thumbnail preview settings in your existing profile so they match the thumbnail preview settings of the "reset" profile Tools > Options > Open & Save > Thumbnail Preview Settings
Thank you for your suggestion,
I will try to restore the thumbnail preview if the problem occurs again.
Best regards,
Wassim
