Hi there,
I am looking into using Dynamic Blocks to give us differnt variations of very similar parts. A very simple example being...
I'm finding my block just doesn't behave how it should. When I change between configurations, the Width changes but the Height doesn't. I have attached the file.
Solved by doni49. Go to Solution.
I'm not quite sure how but I seem to have solved that problem. My next problem is that I have an attribute which I need to display. It appears when editting my block...
But when I return to my model, it's gone. Even when I have 'Display all attributes' activated.
Type in "ATTSYNC" then pick your block.
EDIT: The other possibility that I can think of is if you are using Visibility states, is the attribute in a different Vis State? I don't have time at the moment to deal with downloading the file to test this myself.
Don Ireland
Engineering Design Technician
After posting my last message, I was informed the person that I'm supposed to be meeting is going to be late. So I tried opening your file (in Acad 2012). I got a message that the file couldn't be opened because it was last saved in a newer version.
So what version is it?
Don Ireland
