AutoCAD 2012
Windows 7 Professional
Performed complete uninstall of AutoCAD 2012 including registry and file cleanup.
Ran deployment installer and install fails with message: AutoCAD® 2012 : INSTALLSTATE_INSTALLED
Full log file entry:
2015/1/5:09:32:32 acad_user MIKEOMPUTER === Setup started on MIKEOMPUTER by acad_user ===
2015/1/5:09:32:32 acad_user MIKEOMPUTER Launch
2015/1/5:09:32:37 acad_user MIKEOMPUTER AutoCAD® 2012 : INSTALLSTATE_INSTALLED
2015/1/5:09:32:37 acad_user MIKEOMPUTER SSE2 Support Check : INSTALLSTATE_INSTALLED
2015/1/5:09:32:37 acad_user MIKEOMPUTER .NET Framework Runtime 2.0 : INSTALLSTATE_INSTALLED
2015/1/5:09:32:37 acad_user MIKEOMPUTER .NET Framework Runtime 4.0 : INSTALLSTATE_INSTALLED
2015/1/5:09:32:37 acad_user MIKEOMPUTER .NET Framework Runtime 4.0 Language Pack : INSTALLSTATE_NOT_INSTALLED
2015/1/5:09:32:37 acad_user MIKEOMPUTER Microsoft Visual C++ 2008 SP1 Redistributable (x86) : INSTALLSTATE_INSTALLED
2015/1/5:09:32:37 acad_user MIKEOMPUTER Microsoft Visual C++ 2008 SP1 Redistributable (x64) : INSTALLSTATE_INSTALLED
2015/1/5:09:32:37 acad_user MIKEOMPUTER DirectX Runtime : INSTALLSTATE_NOT_INSTALLED
2015/1/5:09:32:37 acad_user MIKEOMPUTER FaroSDK : INSTALLSTATE_INSTALLED
2015/1/5:09:32:37 acad_user MIKEOMPUTER MSXML 6 : INSTALLSTATE_INSTALLED
2015/1/5:09:32:37 acad_user MIKEOMPUTER Microsoft Windows Media Format 9.5 Series Runtime : INSTALLSTATE_INSTALLED
2015/1/5:09:32:37 acad_user MIKEOMPUTER Autodesk Material Library 2012 : INSTALLSTATE_NOT_INSTALLED
2015/1/5:09:32:37 acad_user MIKEOMPUTER Autodesk Material Library 2012 - Low Resolution : INSTALLSTATE_NOT_INSTALLED
2015/1/5:09:32:37 acad_user MIKEOMPUTER Autodesk Content Service : INSTALLSTATE_NOT_INSTALLED
2015/1/5:09:32:37 acad_user MIKEOMPUTER Microsoft Visual C++ 2005 Redistributable (x86) : INSTALLSTATE_INSTALLED
2015/1/5:09:32:37 acad_user MIKEOMPUTER Internet Explorer 6 : INSTALLSTATE_INSTALLED
2015/1/5:09:32:38 acad_user MIKEOMPUTER === Setup ended ===
2015/1/5:09:32:28 acad_user MIKEOMPUTER === Setup started on MIKEOMPUTER by acad_user ===
2015/1/5:09:32:28 acad_user MIKEOMPUTER Launch
2015/1/5:09:32:40 acad_user MIKEOMPUTER === Setup ended ===
Any suggestions on how to re-install AutoCAD 2012 using this deployment image would be greatly appreciated.
Thank you.
Solved by Alfred.NESWADBA. Go to Solution.
follow that links:
HTH, - alfred -
Thanks Alfred, much appreciated - performed complete uninstall and had to remove all C++ distributibles as well to get AutoCAD installed again.
