I have read everything I can find in the search results and tried a lot of suggestions but my issue is a jerky pickbox in only one drawing file and it just started after working in this file for a month or so. All other files are fine. Everything I have found relates to the problem in all files and not just one. Is there anything that is in this particular file that would cause this?
It's to the point that the file is useless and over a month of work is lost. I've tried copy/paste into a new file for the lack of knowing anything else to do.
I really need to salvage this file. I make frequent copies of all files as I progress with them and unfortunately I copied this file just before the issue arose and that copy file is also contaminated. I've learned now that you can backup files too often!
Anyone have a suggestion? Please.
Russell
Solved by doni49. Go to Solution.
No, but it is similar to snap but far more erratic than snap and it is only in one particular file. All other files are fine.
Yes Nestly, very many times through the night and that corrects the problem.........except when I close the drawing and reopen it the problem is back.
Thanks for the suggestion.
Russell
Can you post your file?
Don Ireland
Engineering Design Technician
Sorry for the delay in responding. Out of Pocket all day. The file is 3,500 KBs and it will not go.
Russell
One additional symptom. I can start a fresh file and copy/paste the problem drawing into it and all is fine...until I close the file and re-open it and then it's back to being jerky again.
Russell
Don Ireland
Don Ireland
Don Ireland
Don Ireland
I'm glad to see that you were able to get it posted. I'm off for the weekend. I'll try it Monday morning.
Don Ireland
I think you tried to provide a link to the file but you didn't share the file.
Don Ireland
Well, I'll go over the tutorial once again and give it another try. Hopefully you'll have it Monday. At 66 things don't come easy anymore!
Russell
