Nothing built-in if I understood your need: try asking in on of these forums instead
Lisp Customization Discussion area:
http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/bd-p/130
Visual Basic Customization Forum:
http://forums.autodesk.com/t5/Visual-Basic-Customization/bd-p/33
Autodesk ObjectARX Customization Forum:
http://forums.autodesk.com/t5/Autodesk-ObjectARX/bd-p/34
.NET Customization Forum:
http://forums.autodesk.com/t5/NET/bd-p/152
I hope it is possible using Design Center but I have a work around to catch those files which has reference to a particular image file.
Here I use a tool BatchInDatabase which is available to download from Autodesk Exchange Apps as a Free tool.
Steps
1. add the list of files which you think that there could be chances for the reference file attached or load all the files within a folder
2. add the command "image-Detach_Reload_unload" and select the file which has to be searched or use the Image name option
3. select uload option and apply the command to all the files which you have loaded in to Batch
4. Run the batch with "Do not Save option" as this will discard the changes and the batch status log will report the existance of such file.
As I have said this is not a straight forward answer to you but a work around to find the reference of image file in the drawing
The batch process is being done without opening the drawings, So the process will be quicker. Hope this will help you
The warning message means you need to add the command to files, individual commands can be added to selected files.
Thers is a little learning curve is needed to use this tool to its full potential, for a quick learning watch the learning videos which are available in the below links and help file availble to download
http://cadmanagertools.com/Downloads_BID.aspx
extract plot style from drawings
I think of replacing image from jpg to png by using another command "Xref-Redirect" which allows to use it as a find and replace action.
For example
case-1
You have an image "Test.jpg" which has been referenced in multiple files
You create another image with same name but different image type, let us say "Test.png"
Since we are changing only the extension and path will remain same, so both images should be in the same folder, the command checks the file first for its location, if found then replace the name, thus the reference is changed to new image type.
case-2
You have an image "P:\ABC-123\DD\Iamges\Test.jpg" which has been referenced in multiple files
You have another image which is located in diffrent directory "P:\ABC-123\WD\Images\Test.jpg"
here we have a part of image path is different, the command parameter will be as below
case-3
You have another image which is located in diffrent directory "P:\ABC-123\WD\Images\NEW.png"
here we have a different path, file name and image type, the command parameter will be as below
Hi LisaPohlmeyer,
Please refe to below link and I have an updated command added "Image - Is Referenced" which will create csv files storing all the drawings which has rerence to a single or multiple images, have a look and let me know
http://forums.autodesk.com/t5/AutoCAD-2010-2011-2012-DWG/Reference-Manager/td-p/4719003
Abubakars
It is doable but it would take 2 processess,
1. Search files whish has reference to image using command "Image-Is Referenced" that create the drawing lsit
2.Load the drawings list in to the Batch process, add the commands, "Image-Detach" to remove the images and "Xref-Insert" or "Block-Insert" to insert your dwg files,
Hope this will be a solution that I could think of now, The tools BatchInDatabase and BatchInEditor are comes with multiple built-in commands, so there may be more than one way to get the job done using them.
