the sysvar FILLMODE is valid for all type of fillings, polyline with width, hatches, true-type fonts. You can't enable/disable it by objecttype seperately.
If might be a help (not the best workarounds, but at least workarounds) to use:
a) command _WMFOUT and then _WMFIN to export the outlines of the polylines and reimport them as new objects
b) use command MLSTYLE and MLINE to define a multilinestyle and draw a multiline.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2024------------------------------------------------------------------------------------
(not an Autodesk consultant)
