Last night I was playing around in Autocad. Today I go to open it up and I don't have a cursor in my model window. the cursor on my mouse will highlight things in the ribbon, but when I click on anything it just highlights, then nothing happens. I have also noticed that in the command line I can mouse click and there is a blinking cursor, but nothing can be typed into it. I am at a loss about now...Anyone have any suggestions? It is Autocad 2012 SP2.
Thanks in advance for any help
Carl
First, I would make sure SNAP off (F9) just in case your snap spacing is larger than your screen.
2nd, if Hardware Acceleration is OFF, turn it ON (and vice versa) Note, disabling hardware acceleration isn't a long term fix, it's just a step to help isolate the problem.
Thanks for your reply. I have found the problem. (or what is causing the problem). I have a 3D Connexion mouse and when I unplugged it everything was ok. Looks like I may have to re set everything in it.
Carl
Carl
Open the 3D Connexion Control Panel and click Calibrate (we do this every morning).
Do not let ANYTHING rest against the puck overnight.
