sorry to say, but I get the same result, so it seems to be really defect..
Functions like _AUDIT or Map3D-DrawingQuery (which helps in some similar cases) did not help.
At least one of the packages I tried gave the message "unexpected fileend" so I guess if you have transfered it by mail or by download the transfer was interrupted.
The chance you have: redownload if you have the option, if the file was save on your workstation you might try to use the BAK file or at least take the DWG from a backup.
Sorry, - alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2024------------------------------------------------------------------------------------
(not an Autodesk consultant)
