Please see the attached file. When you flip through the visibility states, you'll see that "top/bottom north/south" has too many objects showing. "R/L Up/down" has no solid hatch. BUT, when you go into these states on block editor, you don't see this problem. So I have no idea how to fix what I can't see.
I can give more details on how I created it, if no one's able to spot what's causing this.
@Anonymous wrote:
.... So I have no idea how to fix what I can't see.
Inside the Block Editor, there is a button on the Visibility panel named "Visibility Mode". Toggle it and it will display all the objects regardless of their visibility states. I don't know what caused the problem with the block, but I was able to repair it by toggling the objects in the two problem visibility states OFF, then back ON again.
Also, there is a forum dedicated to Dynamic Blocks forum. which is were you should post Dynamic Block specific questions in the future. 🙂
Will do.
Let me make sure I understand you:
Visibility mode button on my AutoCAD allows only two options: turning on all visibility states or just the current one. So I'm guessing you're saying that you went to one of the visibility states that doesn't have a problem, and used visibility mode to turn on all the states, then turn them back off again? Or else you went to one of the problem visibility states and turned all states on and back off again? Because I tried it both ways and neither effected a change to the problem.
Thanks for your patience, this is a problem I've never run into before.
Yes, you did have it right the first time.
And, yes, there is a way to delete, using the "Options" menu at the right of the message, but you have to do it before someone replies. (Sorry.)
morganism3 wrote:
...Visibility mode button on my AutoCAD allows only two options: turning on all visibility states or just the current one. So I'm guessing you're saying that you went to one of the visibility states that doesn't have a problem, and used visibility mode to turn on all the states, then turn them back off again? Or else you went to one of the problem visibility states and turned all states on and back off again? Because I tried it both ways and neither effected a change to the problem.
For some reason, the problem hatch does not show up in the individual visibility states, but it does if you use the visibility states button to display all the visibility states. Once you can see the problem object(s), then you can re-assign them.
