I have a problem that the software is not responding and freezing when creating new drawing or opening another one.
please I want to fix this issue as I have windows 7 64 bit Operating system installed on workstation Dell Machine
I look to a lot of discussion and I tried the mentioned ways but still same issue
FYI, this software was working fine with windows XP machine.
I need your kind help for solving this issue as it is causing a problem for us.
Solved by braudpat. Go to Solution.
Solved by pendean. Go to Solution.
I did all what you said except the first option whtich batches and updates.
from where I get these updates and batches files?
Thanks again
Hello from France
+1 with Pendean :
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19500680&linkID=9240618
Which releases of MSOFT Dotnet are installed on your Win Seven ?
Bye, Pat
Patrice BRAUD
