AutoCAD Forum
acad.pgp
5 REPLIES 5
Kycau
2483 Views, 5 Replies
acad.pgp
In the acad.pgp file ("Tools" > "Customize" > "Edit Program Parameters (acad.pgp)" ), there are several lists of command alias, and each list contains alias...
Have a look at these two lists from my acad.pgp:
;  -- Sample aliases for AutoCAD commands --
D,         *DIMSTYLE
;  -- User Defined Command Aliases --
D,         *DIMLINEAR
so, you see, I have the same alias for two commands... Correct me if I am wrong, but as far as I understand, the alias from ";  -- User Defined Command Aliases --" just have the highest priority in the acad.pgp. Am I right ?
This way, I can edit the ";  -- User Defined Command Aliases --" alias list in the Notepad, without bothering myself, if this alias is already used in the ";  -- Sample aliases for AutoCAD commands --  ". Is this so ?)
Tags (3)
5 REPLIES 5
pendean
in reply to: Kycau
AutoCAD will read the last entry it finds: so if D=Dimlinear is at the bottom of the ACAD.PGP file that is what D will get assigned to. That's why the user defined section is at the bottom.
Kycau
in reply to: pendean
thx )
now I know exactly how it works
Kycau
in reply to: Kycau
What does
; Aliases for commands discontinued in AutoCAD 2004:
mean ?
That in AutoCAD 2009 o earlier these alias will not work ?
cause I use AutoCAD 2011, and at least one command from the list works (BMOD, *BLOCK).
pendean
in reply to: Kycau
Someone at Autodesk decided to mask dead commands with other current/available commands to help those users that may not know it.
Kycau
so that's the point, that ALL of them work in AutoCAD 2011...
For exemple:
; Aliases for commands discontinued in AutoCAD 2000:
DDATTDEF,   *ATTDEF
ATT,       *ATTDEF
both of them work properly in my AutoCAD 2011 🙂
English is not my native language, but "; Aliases for commands discontinued in AutoCAD 2000:" I would understand as if they don't work in Autocad 2000+ versions.
Forma Design Contest
