AutoCAD 2000/2000i/2002 Archive (Read Only)
Hatch Pattern Probs
2 REPLIES 2
185 Views, 2 Replies
Hatch Pattern Probs
Hi
I am trying to draw the 'Gravel' hatch and ' Concrete' hatch and they are
not the normal hatch pattern they are showing chaotic broken lines in the
hatched area. Do I have a setting wrong?
I have copied the acad.pat from another machine to mine and still have the
problem.
Any suggestions?
2 REPLIES 2
I don't know how to fix it, but I have found that if I set my snapbase closer to where I am trying to hatch, it works for me. Then I can reset my snapbase variable to 0,0 and the hatch still appears correctly in the drawing. I don't know what would happen if you left your snapbase set to something other than 0,0
Check to see if the scale for the hatch pattern is correct in the properties...sounds like the scale might be to big
