I can't work out why.
Cheers
Carl
Ok so I think I figured it out. Maybe the tutorial documentation misses a step.
Need to trim the surface after making the intersection.
Thanks for the pointer! I am doing the same tutorial at the moment.
Though I do have a problem even earlier on the same page of this tutorial:
"Use display symmetry to show continuity
6. Hold down the key to magnet-snap, and click-drag with the to move the picked CV upward. Move the cursor near the first CV of the same curve, and the picked CV snaps to the same height as that CV."
When I do this step, the curve looks ok. But it does not affect the surface. It looks like there is no link between the curve and the surface at all.
Did you have any trouble with that step?
Hi
No sorry I didn't have a problem with that and from what you said I'm not sure what could help you.
I gave up on this tutorial. I downloaded Alias 2011 which has much better tutorials and am progressing through those (using Alias 2012).
cheers
