If I wanted to have Alias startup with specific wire file everytime with set construction settings, shaders, environments, cameras etc. how can I do this. Where is the initial wire file saved ?
Solved by c3systems. Go to Solution.
You can launch Alias with a path to a wire file as an argument.
"E:\Program Files\Autodesk\AliasAutoStudio2024.1\bin\Alias.exe" -a as c:\absolute_path_to_wirefile
-a as AutoStudio
-a ss SurfaceStudio
-a cs ConceptStudio
-a le Learning Edition
By default the Alias will use the UserPrefs folder is in %APPDATA%\Autodesk\Alias\UserPrefs [version no.]
Please be reminded that users will have different way of working and their muscle memory set to use those settings. It might be counter productive to be too restrictive.
I would highly recommend to use the new Workspaces introduced in Alias 2024.0. Create customized version of %APPDATA%\Autodesk\Alias\UserPrefs2024.1\AutoStudio\Preference_Sets\User Profile.json file.
Hope it helps.
