Visual LISP, AutoLISP and General Customization
named vieport
9 REPLIES 9
Message 1 of 10
EgoonS
676 Views, 9 Replies
named vieport
hi all, whom of the many readers of this forum has a lisp that delete multiple named vieport in model space at once? share please.
many thanks!
Gee
9 REPLIES 9
Message 2 of 10
_Tharwat
in reply to: EgoonS
This ?
(defun c:Test (/ v)
  (while (setq v (tblnext "VIEW" (null v)))
    (if (eq (cdr (assoc 70 v)) 0)
      (vla-delete
        (vla-item (vla-get-views
                    (vla-get-ActiveDocument (vlax-get-acad-object))
                  (cdr (assoc 2 v))
  (princ)
)(vl-load-com)
Message 3 of 10
EgoonS
in reply to: _Tharwat
HI Thalwart, thanks for your effort..i'd tried but it doesn't work. im using acad2012 that maybe the case?
TiA
Message 4 of 10
Lee_Mac
in reply to: EgoonS
Maybe something along the lines of:
(defun c:dvp ( )
    (vlax-map-collection
        (vla-get-viewports (vla-get-activedocument (vlax-get-acad-object)))
        'vla-delete
    (princ)
(vl-load-com) (princ)
Message 5 of 10
EgoonS
in reply to: Lee_Mac
thanks Lee_Mac. that solved the issue.
Message 6 of 10
Kent1Cooper
in reply to: EgoonS
@EgoonS wrote:
... a lisp that delete multiple named vieport in model space at once? ....
Another way, if you're looking to get rid of all named model-space Viewport configurations:
(command "_.model" "_.vports" "_delete" "*" "" "_single")
You could stop with the "*" if you don't mind being left in whatever Viewport configuration you're in at the time, even if it no longer has a name.
But if by "multiple" you don't necessarily mean all, you can do this if you know the names, with a comma-separated list of them:
(command "_.model" "_.vports" "_delete" "VPName2,VPName3,VPName8")
Kent Cooper, AIA
Message 7 of 10
Lee_Mac
in reply to: EgoonS
You're welcome EgoonS - glad it helps.
Message 8 of 10
_Tharwat
in reply to: EgoonS
TiA
I am sorry , I thought that you want to delete views that are in Model space only whilst you need to delete viewports .
Message 9 of 10
EgoonS
in reply to: Kent1Cooper
thanks Kent to your suggestion
Message 10 of 10
EgoonS
no worries here..anyways, many of you guys made our work much easier.
Forma Design Contest
