how can you get the last point you picked on a Circle because I was going to run the TTR and use the tanget command and have it exit and I need to get the point I pick on the circle
Interestingly, if you draw a Circle using the 3P or 2P option, the last point you picked to define it is stored in the LASTPOINT System Variable, so you can get at it via (getvar 'lastpoint) or with "@" in some kind of drawing or editing command. But with the Center-Radius approach, the point selected to define the radius is only used to calculate the length of the radius, and is not saved, nor do elements of defining selections in the TTR option have any influence on LASTPOINT.
@cadking2k5 wrote:how can you get the last point you picked on a Circle because I was going to run the TTR and use the tanget command and have it exit and I need to get the point I pick on the circle
What exactly are you trying to accomplish? Maybe there's another way to get you there.
For example, the latest post commented on the fact that you couldn't get the last point used to create a circle if using the standard center/radius method. This will get you there if that were needed.
(command "circle" (setq cen (getpoint "Center of Circle: ")) (setq pt2(getpoint "Point on Circle" cen))); pt2 will have the second point that was selected.
Don Ireland
Engineering Design Technician
Looking at that again, I am wondering: If you're drawing the Circle using the TTR option, which most replies here don't really address, you don't directly pick a point that lies on the Circle's circumference, nor do you pick the center point, and you can't save two points to variables and build the Circle from them, but the center is calculated from the tangent objects and the specified radius. The resulting Circle could touch either of the tangent objects sometimes rather far from where the cursor was when you picked near them. By "the point I pick on the circle," do you mean the point of tangency and intersection of the new Circle with one of the tangent objects? Or the nearest point on either the new Circle or one of the tangent objects to the location at which you picked? In either case, would it matter whether it saved the first one or the second one, or would either one do?
@doni49 wrote:
.... you couldn't get the last point used to create a circle if using the standard center/radius method. This will get you there if that were needed.(command "circle" (setq cen (getpoint "Center of Circle: ")) (setq pt2(getpoint "Point on Circle" cen))); pt2 will have the second point that was selected.
A drawback of that approach [which I think is, give or take, what stevor was suggesting] is that the Circle doesn't drag dynamically as it's asking you for the circumference-defining point, so you can't see what you're getting as in the regular Circle command. It would be possible using (grread) to have it drag while asking for a picked point that it would be able to save, but I don't believe object snap would be available for that point. [At least, I haven't found a way to get it to work, nor to type in a one-time Osnap mode, in a routine I built that draws a Rectangle based on a midpoint rather than on opposite corners.]
But in any case, it's moot if they're drawing the Circle using the TTR option [waiting for an answer to my clarification question about that] -- I expect it would require some other approach entirely.
@Kent1Cooper wrote:
@doni49 wrote:.... you couldn't get the last point used to create a circle if using the standard center/radius method. This will get you there if that were needed.(command "circle" (setq cen (getpoint "Center of Circle: ")) (setq pt2(getpoint "Point on Circle" cen))); pt2 will have the second point that was selected.
Good point Kent. I guess we'll have to wait for clarification. If we knew exactly what the OP is trying to accomplish, we might be able assist in finding another aproach.
Don Ireland
@Kent1Cooper wrote:
....A drawback of that approach [which I think is, give or take, what stevor was suggesting] is that the Circle doesn't drag dynamically as it's asking you for the circumference-defining point, so you can't see what you're getting as in the regular Circle command. It would be possible using (grread) to have it drag while asking for a picked point that it would be able to save, but I don't believe object snap would be available for that point. ....
I worked out a way to do that, in case it's of any use to the OP, but it does have the drawback described -- it honors neither running Object snap nor entry of a one-time Osnap mode for the circumference point [it does for the center]. And it won't let you set the value of, or turn on or off, positional Snap between picking the center and the point on the circumference, but it does honor positional Snap if it's already on.
