I often have DXF files that contain very many short (10 digits or less) instances of text, and only a few long instances of text (11 digits or more)....
I would like to use AutoLISP to delete all of the short text in my DXF file, but leave the longer text.
Can anyone tell me a good way to go about doing this???
Beginning to intermediate-ish user.
Here's a quick example for you:
(defun c:delshorttxt ( / e i s ) (if (setq s (ssget "_X" '((0 . "TEXT")))) (repeat (setq i (sslength s)) (setq e (ssname s (setq i (1- i)))) (if (<= (strlen (cdr (assoc 1 (entget e)))) 10) (entdel e) ) ) ) (princ) )
(defun c:deleteTheShorties (/ ss i e)
(if (setq ss (ssget "_X" '((0 . "TEXT") (-4 . "<NOT") (1 . "???????????*") (-4 . "NOT>"))))
(repeat (setq i (sslength ss)) (entdel (ssname ss (setq i (1- i)))))
(princ)
EDIT: I can't belive they don't filter smilies in code blocks.
Nice use of the filter list Alan.
I initially considered using:
(1 . "??????????,?????????,????????,??????? ....")
But hadn't thought of using the reverse logic.
And yeah, the code panes on this forum are useless.
You can also try ALTEXT.vlx which can replace any numbers less than a certain number with a blank " ".
In the settings, select "New", "Number", "New text" = " ", and define "Start from" and "End at".
3wood
@alanjt_ wrote:(defun c:deleteTheShorties (/ ss i e)
(princ)
If there aren't complications of multiple Layouts or something [can DXF files even have those?], you can get rid of them all in one shot, instead of individually:
(defun c:deleteTheShorties (/ ss)
(command "_.erase" ss "")
(princ)
Yes, the (command) approach may "take longer" measured perhaps in small fractions of a second depending on the quantity of Text entities. Could it be that, with enough of them, the fact that one operation gets rid of them all, rather than a separate operation for each, would make up the difference?
But the real reason I'm replying is: I don't generally deal with DXF files, but that's what the original question is about. Would this require opening each file as a drawing [or perhaps DXFINing it into one], running the routine, and DXFOUTing it, or SAVEASing it as a DXF, to overwrite the original file? Or can such a thing be applied to a DXF file without actually opening it? Or is there another way to do that?
(princ)
(princ)
You may not being iterating through the selectionset, but the ERASE command is.
(princ)
This line does the same thing
(1 . "~???????????*") without the NOT
Whats the diffrenece?
This discussion was soooo cute! Thank you for brightening my day.
John F. Uhden
How do you find time digging around old post on your OOSRBTW [ Out-OF-Semi-Retirement Back To Working Class ] status? I would think you'll be spending less time on the forum for nowadays
Lean back on your chair, look up in the ceiling and read the message I posted there.
Made you look!
But if I would've posted a message there, it would be like this
((4 1) (3 2) (8 1) (0 1) (2 2) (2 1) (2 3) (5 2) (0 1) (8 1) (6 3) (0 1) (9 1) (6 3) (7 3) (5 2) (0 1) (9 3) (6 3) (8 2) (0 1) (7 4) (5 3) (2 1) (2 3) (5 2) (3 2) (7 3))
or
((4) (3 3) (8) (0) (2 2) (2) (2 2 2) (5 5) (0) (8) (6 6 6) (0) (9) (6 6 6) (7 7 7) (5 5) (0) (9 9 9) (6 6 6) (8 8) (0) (7 7 7 7) (5 5 5) (2) (2 2 2) (5 5) (3 3) (7 7 7))
Hint:
To make this more interesting, write a lisp code to decipher the message.
Have fun John.
"get?abc?k?t..............."
Whuh?
BTW, I am having fun. I am at work waiting for the Russian gal to show me how to get into C3D 2014 on another machine. Mine has only C3D 2010.
John F. Uhden
Whuh?
Haha 😄
But If you are still interested because I see you get the general idea..
((4 1) (3 2) <-- The second element is the number of times you press the key
(8 1) (0 1) <-- 0 usually represents a space |__| where i came from
or
((4) (3 3)<- two times
(8) (0)
Cant say I blame you, guess its too much to ask a guy to ignore a Russian gal just to put a little effort in writing a code for fun 🙂
Anyhoo...
Cheers
She's not that kind of a Russian gal. She's over 60 and I really can't understand what she is trying to say. Yeah, I know, 60 is like a kid to me, but she still doesn't qualify. I'll look at your secret code another time.
John F. Uhden
That was fun.
(defun nokiaDays1 (message) ((lambda (keyPad) (apply 'strcat (mapcar (function (lambda (x) (nth (cadr x) (assoc (car x) keyPad)))) message)) ) '((2 "A" "B" "C") (3 "D" "E" "F") (4 "G" "H" "I") (5 "J" "K" "L") (6 "M" "N" "O") (7 "P" "Q" "R" "S") (8 "T" "U" "V") (9 "W" "X" "Y" "Z") (0 " ") ) ) )
(defun nokiaDays2 (message) ((lambda (keyPad) (apply 'strcat (mapcar (function (lambda (x) (nth (length x) (assoc (car x) keyPad)))) message)) ) '((2 "A" "B" "C") (3 "D" "E" "F") (4 "G" "H" "I") (5 "J" "K" "L") (6 "M" "N" "O") (7 "P" "Q" "R" "S") (8 "T" "U" "V") (9 "W" "X" "Y" "Z") (0 " ") ) ) )
BTW, John, my introduction to CAD was drawing surveys for my Dad.
They were running AutoCAD 14 with Cadvantage (CPlus?) loaded. Great piece of software.
Thanks for the compliment. What was the name of the company for whom you worked? Where were they located? I don't understand "CPlus."
John F. Uhden
