I tried to create a shortcut on a hidden command "Overkill"
I was using autolisp to shorten the command to "OK". It comes in handy when it is time to clean up my drawings.
When I tried, autocad said "Unknown command "-OVERKILL" "
I thought I had everything correct, any suggestions?
HD
I've done this myself simply by editing the acad.pgp file or you could use the command alias editor in express tools. I use this little gem all the time. Good luck.
OVERKILL is not a standard autocad command, it is lisp it self (from Express Tools) and you can not call a lisp function from (command) function
but you can do this:
(defun C:OK ()
(c:overkill) ; or (c:-overkill) for the command line version
not that if express tools will fail to load OK function will fail also and it is better
to verify that Express Tools is memory
Cheers
Moshe
Thank you for the suggestions, I will give them a try and let you know of the outcome.
HD
