I have the same issue, but I don't want to remove the unresolved menu groups. I need to fix them.
I load a custom menu through the enterprise cuix file and it works fine on one pc, but not on others.
I've checked file search paths and everything is setup the same that I can find.
It worked fine with 2012, but as soon as I installed 2013, it quit working.
Anyone run into this issue?
Thanks.
In lieu of adding and removing while inside the CUI,
have you tried command CUILOAD?
If this does not work, try the following:
Unload all enterprise menus.
Command MENU and systematically select each partial menu and check for problems.
Is this yet another instance where the right hand does not know what the left hand is doing?
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
For my issue, unloading and loading the CUI's in question didn't work, but I did finally figure it out.
I had to transfer the two menus from the partial CUI's into my enterprise workspace. Then it worked.
That means that anyone not loading the partial CUI's will have a couple of dummy menus that load, but at least it's working for those that need it.
Funny I didn't have to do this with 2012????
The set-desired-workspace-current-first-before-adding-a-enterprise-menu syndrome?
Scot-65
