Visual LISP, AutoLISP and General Customization
To-lin Lisp - Exports linetypes to a new *.lin file
5 REPLIES 5
5309 Views, 5 Replies
Higuys,
Just wondering if anyone knows if this lisp will work on Windows 7??
We've recently upgraded to 2012 on windows 7 from 2008 on XP and i treid to use this lisp yesterday but it didn't work.
I can't remember if it write the file new lin file to the drawing file location or if it goes to the C drive.
Our IT dept. have locked off pretty much everything except our desktops so maybe that an issue!!
5 REPLIES 5
This lisp is working fine on win7 and AutoCad 2012,
lin file is created in my document.
I am using totalcommander, and if you open drawing from him, files will be created in folder where is drawing location.
That's weird! It works for me, says it creates the file but I can't find it anywhere on my pc!!
Try to search for file which was created,
Type in start search:
NEWLT.LIN
I did try that no file with that name on my pc!
Try with this, i  test it only once and it suppose to alert you where is your file located.
 I just added these two lines:
(setq fileloc (findfile "newlt.lin"))
(alert (strcat "Your file location: " fileloc))
And try to set  variable  REMEMBERFOLDERS to 0,
if it is set to 0 your file will be saved at the same folder where is the drawing which you opened.
Forma Design Contest
