That doesn't seem to be working. I'm stuck in the 'Select text objuects to mask or [Masktype/Offset]"
Here is the command line: (the ** are my comments)
Command: _textmask
Current settings: Offset factor = 0.350000, Mask type = Solid, Mask color = 200
Select text objects to mask or [Masktype/Offset]:
1 found **(this is the text I selected)**
Select text objects to mask or [Masktype/Offset]: **(right-click or enter to end selection at this point)**
If I continue to right-click or enter it will just continue to give me the same line.
