Set PSLTSCALE help
11 REPLIES 11
Message 1 of 12
422 Views, 11 Replies
Set PSLTSCALE help
I am trying to write a function to change all the layouts to PSLTSCALE = 0
Below is what I have so far BUT IT DOESN'T WORK!!! I think I am supposed to change this:
(100 . "AcDbLayout") (1 . "Layout1") (70 . 1)
to this:
(100 . "AcDbLayout") (1 . "Layout1") (70 . 0)
but I don't know how to access the (100 . "AcDbLayout") part of the entity data. SEE BELOW
Let me know if I am barking completely up the wrong tree.
And thanks...
[CODE]
(defun acad-object ()
(cond (*acad-object*) ; Return the cached object
(t
(setq *acad-object* (vlax-get-acad-object))
(defun active-document ()
(cond (*active-document*) ; Return the cached object
(t
(setq *active-document* (vla-get-activedocument (acad-object)))
(defun ppn_set_psltscale (LAYOUTS PS_LTSC / my_layout_ob my_layout_en EN_DATA)
(foreach LAYOUT LAYOUTS
(progn
(setq my_layout_ob (vla-item (vla-get-layouts (active-document)) LAYOUT))
(setq my_layout_en (vlax-vla-object->ename my_layout_ob))
(setq EN_DATA (entget my_layout_en))
(setq EN_DATA (subst (cons 70 PS_LTSC) (assoc 70 EN_DATA) EN_DATA))
(entmod EN_DATA)
(defun c:pslts ( / *acad-object* *active-document*)
(ppn_set_psltscale (layoutlist) 0)
[/CODE]
EN_DATA =
((-1 . ) (0 . "LAYOUT") (5 . "3829C") (102 .
"{ACAD_XDICTIONARY") (360 . ) (102 . "}") (102 .
"{ACAD_REACTORS") (330 . ) (102 . "}") (330 .
name: 7ef56c70>) (100 . "AcDbPlotSettings") (1 . "11x17") (2 .
"HP5000-South.pc3") (4 . "11x17") (40 . 4.23333) (41 . 4.23334) (42 . 8.46667)
(43 . 4.23334) (44 . 279.4) (45 . 431.8) (46 . 0.0) (47 . 0.0) (48 . 0.0) (49 .
0.0) (140 . 0.0) (141 . 0.0) (142 . 1.0) (143 . 1.0) (70 . 0) (72 . 1) (73 . 1)
(74 . 1) (7 . "RJC HP DesignJet 1050 100% TransBond.ctb") (75 . 0) (147 . 1.0)
(76 . 0) (77 . 2) (78 . 300) (148 . 0.0131826) (149 . 0.00854427) (100 .
"AcDbLayout") (1 . "Layout1") (70 . 1) (71 . 1) (10 0.0 0.0 0.0) (11 12.0 9.0
0.0) (12 0.0 0.0 0.0) (14 1.0e+020 1.0e+020 1.0e+020) (15 -1.0e+020 -1.0e+020
-1.0e+020) (146 . 0.0) (13 0.0 0.0 0.0) (16 1.0 0.0 0.0) (17 0.0 1.0 0.0) (76 .
0) (330 . ) (331 . ))
11 REPLIES 11
Message 2 of 12
Hi Sherm!
I'll try to help you but I have one question:
Why do you use VL methods? Is it essentially to you? ; )
I give you the example how to get this info with pure AutoLISP
and you will made changes to modify PSLTSCALE:
;; Example: (getpsltscale (getvar "ctab"))
(defun getpsltscale ( layout_name / getlayoutinfo layoutinfo
layout_psltscale)
(defun getlayoutinfo ( layout_name / allayouts cps_en cps_elist )
(setq allayouts (dictsearch (namedobjdict) "acad_layout"))
(setq cps_en (cdr (assoc 350 (member (cons 3 layout_name)
allayouts))))
(setq cps_elist (entget cps_en))
cps_elist
) ; - 'defun'
(setq layoutinfo (getlayoutinfo layout_name))
;; the "trick" :^) to get the DXF70 of your dream!
(setq layoutinfo (member (cons 100 "AcDbLayout") layoutinfo))
(setq layout_psltscale (cdr (assoc 70 layoutinfo)))
layout_psltscale
) ; - 'defun'
Now you have to
- save the beginning of the entire list,
- then modify DXF70,
- then reconstruct the list back,
- then ENTMOD it.
AutoCAD loves you!
Alexander V. Koshman
Message 3 of 12
So it seems to do everything its supposed to do but PSLTSCALE doesn't change??!?!?!?!
So there must be something I am missing.
I have put it in the "too hard basket"
The following code seems to work fine. It updates the data for each layout in the drawing to set what I thought was the value for PSLTSCALE....BUT
psltscale doesn't actually change??
If anyone has any ideas what else needs to be done>>>
Otherwise its too hard for me so I give up!.!.!.!
(setq *acad-object* nil) ; Initialize global variable
(setq *active-document* nil) ; Initialize global variable
(t
(t
(defun model-space ()
(cond (*model-space*) ; Return the cached object
(t
(setq *model-space* (vla-get-modelspace (active-document)))
(defun ppn_set_psltscale (LAYOUTS PS_LTSC / my_layout_ob my_layout_en EN_DATA EN_DATA_SUB EN_DATA_PRE ITEM #)
(progn
(setq EN_DATA_SUB (member (cons 100 "AcDbLayout") EN_DATA))
(setq EN_DATA_SUB (subst (cons 70 PS_LTSC) (assoc 70 EN_DATA_SUB) EN_DATA_SUB))
(setq # 0)
(while (/= T (equal ITEM '(100 . "AcDbLayout")))
(progn
(setq ITEM (nth # EN_DATA))
(setq EN_DATA_PRE (cons ITEM EN_DATA_PRE))
(setq # (1+ #))
(setq EN_DATA_PRE (reverse (cdr EN_DATA_PRE)))
(setq EN_DATA (append EN_DATA_PRE EN_DATA_SUB))
(entmod EN_DATA)
(setq EN_DATA_PRE nil EN_DATA_SUB nil)
(defun cslts ()
(princ)
Message 4 of 12
Agree!
I did it by myself and discovered that PSLTSCALE of the Layout doesn't
change with ENTMOD...
Just wanted to tell you that! : (
Message 5 of 12
Search these forums for CHANGEDLAYOUT.LSP
It changes the PSLTSCALE to 1, but you can modify the reactor to set it to 0 just as easily.
Message 6 of 12
From RobertB - AUGI Director
Public Sub ResetPSLTScale()
Dim aLayout As AcadLayout
For Each aLayout In ThisDrawing.Layouts
ThisDrawing.ActiveLayout = aLayout
ThisDrawing.SetVariable "PSLTScale", 0
Next aLayout
ThisDrawing.ActiveLayout = ThisDrawing.Layouts.Item("Model")
End Sub
Message 7 of 12
Could only find this one and it doesn't even come close.
However I think you have missed the point. The code I posted is attempting to change PSLTSCALE for all layouts in a drawing no matter how many there are without having to switch manually from one to another (in the case of a simple reactor)
Would be much easier to just open a drawing and enter c:pslts and have all layout changed to PSLTSCALE of 1 or 0 as required don't you think?
;; ChangedLayout.lsp
;; changes LTSCALE when switching MODEL/PAPER.
(defun ChangedLayout (reactor layout / )
(if (= (nth 0 layout) "Model") ; else set to 0.5
(setvar "ltscale" (* (setvar "ltscale" 25) 1 ))
(progn
(setvar "ltscale" 0.5)
(if(not *LayoutLTS*)
(setq *LayoutLTS* (VLR-Miscellaneous-Reactor nil '((:VLR-layoutSwitched . ChangedLayout))))
Message 8 of 12
Ohh, Try this completely untested
(defun c:vppltsc(/ THISTAB VPLST)
(setq THISTAB (getvar "CTAB"))
(foreach LAYOUT (layoutlist)
(setvar "CTAB" LAYOUT)
(setvar psltscale 0)
(setvar "CTAB" THISTAB)
(princ)
Message 9 of 12
Not a bad solution I guess.
For me it was as much a lesson in entity data management as anything else. The whole question was raised by someone else in the AUGI.
Thanks for your input.
Cheers
Sherm
Message 10 of 12
You guess?? What the heck does that mean??
Message 11 of 12
Sorry I meant no offence. It works great.
For me however I was trying to approach it from a direct access point of view and develop a program that would access the dwg data base directly without having to rely on functions like setvar and variables like "CTAB".
Between this forum and AUGI I now have a solution to the original question posted. BUT it was a learning experience for me and I still haven't found out where within the dwg data base the PSLTSCALE is stored for each layout and how to modify it directly. Never mind.
Hypothetically, lets say i wanted to change PSLTSCALE to 1 on 1000 dwg's each with 15 layouts. It would be good not to have to open each one and switch to each layout one by one?!
Now I am not saying I want to do that but as I said it was a learning experience for me.
Again, I do appreciate your input.
Regards
Sherm
PS even the VBA version relies on switching to each layout and changing the scale one by one?.. Message was edited by: Sherm
Message 12 of 12
FWIW,
here is the corrected code to change the PSLTSCALE to 0 in all layouts. Quotes were missing in the original in this thread. I tested the code below out and it worked perfectly for me.
(setvar "psltscale" 0)
(princ)
”Boost
