• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Visual LISP, AutoLISP and General Customization
    *Expert Elite*
    Re: Navigate Viewports
    01-12-2013 09:48 AM in reply to: Lineabove
    Lineabove wrote:
    EXCELLENT !
    Thank you.
    Glad you found what you need Lineabove
    FWIW: Heres a mini rouitne to demonstrate CTAB [from an old routine of mine]
    (defun c:tab ( / CDiaStr ListBoxDia StrDiaFnme lname)
    ;;;	pBe 12Jan2013	;;;
    (defun CDiaStr (/ fnSTR)
      (setq StrDiaFnme
             (vl-filename-mktemp "tmp.DCL" ))
      (setq fnSTR (open StrDiaFnme "a"))
      (write-line
        "dcl_settings : default_dcl_settings { audit_level = 3; }
      ListofLayoutTabs : dialog
      { label = \"\"; key= \"Base\";
      : list_box { key = \"StrListS\";
      width = 20; height = 20; } spacer ;
      ok_cancel;
      }" fnSTR )
      (close fnSTR)
      T
    (defun ListBoxDia  (DiaName Title Lst / el x)
                (setq StrDIA (load_dialog StrDiaFnme))
                (if (not (new_dialog DiaName StrDIA))
                      (exit)
                (start_list "StrListS")
                (mapcar 'add_list Lst)
                (end_list)
                (set_tile "Base" Title)
                (action_tile "StrListS" "(setq el (get_tile $key))")
                (action_tile "accept" "(done_dialog 1)(setq x T)")
                (action_tile "cancel" "(done_dialog 0)")
                (start_dialog)
                (unload_dialog StrDIA)
                (if x (read (strcat "(" el ")")))
    (cond ((and
    	(CDiaStr)
    	(setq lname (ListBoxDia
    	   "ListofLayoutTabs"
    	   "Select Layout Name"
    	   (layoutlist)))
    	   (vl-file-delete StrDiaFnme)
               (setvar 'ctab (nth (car lname) (layoutlist))
          (princ)
    HTH
    Please use plain text.
