My LISP routine wont work.
3 REPLIES 3
866 Views, 3 Replies
Good day all.  I uploaded a lisp file that should autonumber blocks into AC 2012 and AutoCAD shows that it uploaded sucessfuly. However when I go to run the routine i get the error message  'error: bad character read (octal): 4'  Can anyone help?
Tags (2)
3 REPLIES 3
This is not a regular lisp file.  The file ending should not be .lsp.  It is some sort of compiled file as you can not view it in a text editor like Notepad.  So not able to look at the code.
diagodose2009
1) i rename the file InsertC.LSP 17 KB
   to insertc.vlx
2) i load my application faschecker.exe and i got this error:
  "invalid  fas signature"
3) i rename tjhe file insertc.lsp to insertc.fas
4)i load in autocad ,, and appers it it correct!!????
5) i run my application faschecker.exe and i got this error:
6)apparently the file insertc.vlx is broken..
Regards..
in reply to: diagodose2009
You need to be able to look at the code, and don't think this can be done with a compiled lisp program.  I think you need the original lsp program before it was compiled to be able to analyze what is going on, unless someone else has an idea.
Forma Design Contest
