I used to think it was possible through lisp, but I don't think so.
I know there is ScriptPro, but for some reason, I do find it cumbersome.
I have the following string of code, that I'll write in everyone's start-up suite. Thanks to DosLib, I'm able to retrieve a list of files I want to modify, for whatever reason. (One example, when plotting drawings with layouts, sometimes the shadeplot setting is wireframe, and not classic hidden, though it's been set up in our templates).
The huge question is, can I get a list of drawings to a variable in one drawing, and have access to that variable list, in the next drawing I open? I'll iron out the bugs on read-only statuses, or manipulating drawing states later.
KP
; see code below
(defun GetDrawings ()
(setq currentpath (getvar "dwgprefix"))
(command "pspace")
(setq DrawingList (dos_getfilem "Select a file" currentpath "Drawing files (*.dwg)|*.dwg|All files (*.*)|*.*||"))
(setq ListOfDrawings (cdr DrawingList))
(setq DrawingPath (nth 0 DrawingList))
(Alert DrawingPath); just making sure what I'm looking for is what gets returned
(Alert (itoa (length ListOfDrawings))); just making sure what I'm looking for is what gets returned
(princ ListOfDrawings); just making sure what I'm looking for is what gets returned
(setq Element 0)
(setq OpenDrawing (nth Element ListOfDrawings))
(setvar "filedia" 0)
(command "save" "")
(command "open" OpenDrawing)
(defun ScriptInDrawing (/)
(cond
((= DrawingList nil)(GetDrawings))
(T())
(setq Element (+ Element 1))
(command "line" "0,0" "11,11" ""); or some test to see that this works (command "save" "")
(princ))
(defun C:copen (/)
(ScriptInDrawing)
(defun C:aopen (/)
(cond
((= DrawingList nil)(Alert "NIL?"))
(T(ScriptInDrawing))
);T
);defun
(C:AOPEN)
