Hi
I have a file list which contains code x y z ina a space deliminated format. there are six different codes in the file and I want to end up with a list for each code containing just the x y z coordinates so I can create a seperate polyline for each. I have tried a number of methods and not getting very far. The codes are bi,bp,sq,tr,bc,sh.
example is as follows
sq 3.0 100 0
bp 3.1 80 0
sq 3.1 100 0
tr 3.1 40 0
bc 3.2 40 0
sh 3.47 60 0
bp 6.67 80 0
tr 6.67 40 0
sq 6.67 140 0
Not a complete list but enough to be going on with if you have the six diferent codes, the 0 at the end could be left off.
I would like to be able to controll the poliline perameters like line type and color so once the seperate lists are compiled I just set the layer,color,linetype then command a polyline for each of the six lists if they exist.
@richie_hodgson wrote:example is as follows
sq 3.0 100 0
bp 3.1 80 0
sq 3.1 100 0
tr 3.1 40 0
bc 3.2 40 0
sh 3.47 60 0
bp 6.67 80 0
tr 6.67 40 0
sq 6.67 140 0
(defun c:REbuild (/ _delFinder fl a b pl_ RebList)
(defun _delFinder (str md / d l str)
(while (setq d (vl-string-position md str nil T))
(setq l (cons (substr str (+ 2 d)) l)
str (substr str 1 d)))
(cons str l)
(if (and (setq fl (GetFiled "Select point file" "" "txt" 4))
(setq RebList nil fl (open fl "r")))
(progn
(while (setq a (read-line fl))
(setq pointlist (cons (_delFinderc a 32) pointlist))
(close fl)
(while (setq a (car pointlist))
(while (setq b (assoc (car a) pointlist ))
(setq pl_ (cons b pl_) pointlist (vl-remove b pointlist)))
(setq RebList (cons (list (caar pl_)(mapcar 'cdr pl_))
RebList) pl_ nil))
(foreach p RebList (print p)(princ));<test purposed
(princ)
("bc" ((3.2 40 0)))
("sh" ((3.47 60 0)))
("bp" ((3.1 80 0) (6.67 80 0)))
("tr" ((3.1 40 0) (6.67 40 0)))
("sq" ((3.0 100 0) (3.1 100 0) (6.67 140 0)))
HTH
I'm not sure what you want, but this lisp take a file like the example and return a list of lists with the following format: ((code1 point1)(code2 point2)...)
(defun readF(MyFile / fp rl slist p pldata pldatalist) (setq fp (open Myfile "r")) (if fp (progn (while (setq rl (read-line fp)) (setq slist (split rl 32)) (setq p (list (read (nth 1 slist)) (read (nth 2 slist)))) (setq pldata (list (car slist) p)) (setq pldataList (cons pldata pldataList)) ) ) (alert "File not found!") ) (reverse pldatalist) ) (defun split(str char / sl i n e word slist) (setq sl (vl-string->list str)) (setq n (length sl)) (setq i 0) (setq word "") (while (< i n) (setq e (nth i sl)) (if (/= e char) (setq word (strcat word (chr e))) (progn (setq slist (cons word slist)) (setq word "") ) ) (setq i (+ i 1)) ) (reverse (cons word slist)) )
Gaston Nunez
Hi thanks for that, I get ; error: no function definition: _DELFINDERC, it looks like the outputs on your message are what I want, I assume I just need to write a car and cadr statement to separate the code and points so I can use an if statement to write the points to a polyline with colour and linetype, please let me know if I am wrong I am still relatively new to this lisp thing.
@richie_hodgson wrote:Hi thanks for that, I get ; error: no function definition: _DELFINDERC, it looks like the outputs on your message are what I want, I assume I just need to write a car and cadr statement to separate the code and points so I can use an if statement to write the points to a polyline with colour and linetype, please let me know if I am wrong I am still relatively new to this lisp thing.
oops my bad. i posted the wrong sub. replace the code in the previous post with this one
This converts the values as it compiels the list
(defun _delFinderC (str md / d l str)
(setq conv (lambda (k / num word)
(if (numberp (setq num (read k)))
num
k)))
(setq l (cons
(conv (substr str (+ 2 d)))
l)
(cons (conv str) l)
(progn
(close fl)
RebList) pl_ nil))
(princ)
Try it and tell me waht you think
sq 3.0 100 0
bp 3.1 80 0
sq 3.1 100 0
tr 3.1 40 0
bc 3.2 40 0
sh 3.47 60 0
bp 6.67 80 0
tr 6.67 40 0
sq 6.67 140 0
It's not necessary to break the lines up into pieces around the spaces -- point lists in AutoLISP are also space-delimited, so you can keep that aspect of the lines in the file. If the "categories" are always two letters, try this:
(setq fil (open "Y:/our/filepath/and/file.txt" "r"))
(while
(setq lin (read-line fil)); get next line in file
(set (read (substr lin 1 2)); variable name for list of points, from first two characters
(append
(eval (read (substr lin 1 2))); existing list of points for that category, if present
(list (read (strcat "(" (substr lin 3) ")"))); add point for current line
); append
); set
); while
(close fil)
On your example file content, that returns a list of point(s) for each category, stored in a variable named for that category, as follows:
Command: !sq
Command: !bp
Command: !tr
Command: !bc
((3.2 40 0))
Command: !sh
((3.47 60 0))
Hi Richie,
You may also want to take a look at our FREE Lisp resourceson the TechCenter web-site.
Here is the URL:
http://www.4d-technologies.com/techcenter
Over there, you can find Lisp routines for a vast array of common CAD and geo-data processing functions.
In fact, our commercial software add-ons, GeoTools and CADPower are built using the FREE libraries you see in TechCenter.
Let me know if you need any further assistance.
Regards
Rakesh
