Hi all,
it looks like I'm not able to control the dimensions of image slide
Whatever value I use for height and width the image is displayed too small in the tile.
What am i doing wrong ?
Thanks to who can help me.
here's my code:
: image {
key = "sld";
height = 5;
width = 30;
color = 0;
is_enabled = false;
is_tab_stop = false;
fixed_width = true;
fixed_height = true;
aspect_ratio = 1;
(setq width (dimx_tile key))
(setq height (dimy_tile key))
(start_image "sld")
(fill_image 0 0 width height 0)
(slide_image 1 1 (- width 2 ) ( - height 2 ) "CBsagome\\D.sld")
(end_image)
//Title:View SLD file in the platforms autocad.............
Hi..
Please downloading "my demonstation program VLX" bellow......
if downloading failed, then you copy&paste this adress to you adressbar.
If you need the source LISP ,please you send to me,the private message.
step0)unzip all files
step1)You load my application pp_ddvslide
step2)You enter the command Q2 [enter]
step3)You select any SLD file
step4)Have..Fun
hi can you send me the source file or just simple i want to attach one image in my dcl file.can you send me simple dcl file with slide name of myslide.sld to my email address drsvsmani@gmail.com?
hi
Before you created your slide image, did you zoom extent? The bigger the image is on your screen before you create the slide image the bigger it will appear in your image tile.
In additon, close all windows that are on your drawing screen, or move them out of the way.
This includes the COMMAND LINE as well as any property windows or toolbars you may have in the drawing area.
Then turn off your grid.
Make sure you're zoomed all the way to the object and not leaving any portions of it cut out.
Once your screen is filled with your object you simply type
MSLIDE
HTH!
