Have you considered using the PC3 method for each paper size
and/or orientation you may have in your given environment?
Konica-A4-Landscape.pc3
Konica-A4-Portrait.pc3
The only one I have a problem with is the DWG to PDF.
It never wants to remember the paper size (I use CutePDF instead).
If you do employ the PC3 method, suggest hiding the system printers
so as not to be confused with which one you are selecting.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
