Charlie,
This should work most of the time. Be sure to set dimassoc = 2.
(defun c:circum( / )
;;D. C. Broad, 6/5/2004 - Circumference dimension
(command "dim1" "rad" pause "Circ: <>" "exit")
(command "dimoverride" "dimlfac" (* 2 pi)
"" "last" "")
(Princ))
"Charliep" wrote in message news:13052638.1086363817589.JavaMail.javamailuser@localhost...
> Does any one have a routine that will dimension for a Circumference that you would share?
> I know that the circumference can be obtained in the properties box, however it would be nice if it were associative.
> By the way I use A2K4
> Thanks in advanced.
