<dgorsman> wrote in messageDepending
href="news:6353238@discussion.autodesk.com">news:6353238@discussion.autodesk.com...
on the size/complexity of the DVB, you won't see an impact in load times
between load at start-up and load on function call. Given the computers
AutoCAD is running on these days, small-medium DVBs will load virtually
instantaneously (they should also be the easiest to convert to .NET). For you
to see a load delay it would have to be HUGE. You won't necessarily need to
unload it afterwards either, which will bypass loading it multiple times, but
then you run into that max users number.
If the routine is that
important, use it as a learning experience for upgrading to .NET or hire out
to get it converted (make sure you get the source code back as well as the
DLL). You will likely need to do this anyways in a couple of
years.
