Hi all,
I have a client who is would like to create a Change Order Link Property called 'Priority' that can be set to Low, Medium, or High for each record that is attached to a Change Order. According to the Wikihelp, that is exactly the type of info Link Properties are used for: http://wikihelp.autodesk.com/Vault/enu/2012/Help/02._Working_with_Vault/01._Vault_Client/1175VaultSe...
However, they do not appear to be working. Below is the procedure I followed to try to create a Link Property. I have tried this in Vault Professional 2011 Update 2 and Vault Professional 2012. Both have the same result. I have searched the forums, but could not find a solution. Am I doing something wrong or do Link Properties not work?
1. Open the Vault Professional client and go to Tools->Adminstration->Vault Settings. Click on the Change Order tab and click Properties:
2. Click New to create a new property as shown, then click OK:
3. Close out Vault Settings, then create a new ECO with a record. The Property appears, but it cannot be changed.
Clicking on the drop-down arrow has no effect:
4. Go back into Vault Settings and check the Link Property. The settings have been changed:
Kevin Burrows
Technical Specialist
ECAD, Inc.
Solved by carrie.ruan. Go to Solution.
Thank you posting this messge.
The ECO link Property only works for Items in the Records tab, not for files.
I have log a defect to update the wikihelp message.
Carrie
I have also since tried to do this with FILES attached to an ECO. The property appears, but you cannot edit the property. I now understand (after reading this post) that this can only be accomplished by using ITEMS with an ECO.
I have attached the WIKI Help link that talks about linked ECO properties, but mentions NOTHING about how this can only be done with ITEMS. This would have saved me a little bit of time if I knew this ahead of time. Can you please update the WIKI page or put in a request for this to work with files too? Thank you.
Wiki Help: Manage ECO Properties
In looking into this myself, I came across an Ideastation post asking to add this functionality to files. Please go vote on it.
https://forums.autodesk.com/t5/vault-ideas/eco-link-properties-for-files/idi-p/6622029
@KevinBurrows, you posted about this issue in 2011 and never told me. Ten years later, I just now realized why I can't change those properties. Haha!
