Public Test Forum
Message 1 of 11
wrighte
621 Views, 10 Replies
test
🙂  what does that do
Eric Wright
Sr. Web Product Manager
Autodesk Knowledge Network
10 REPLIES 10
Message 2 of 11
wrighte
in reply to: wrighte
and if I put the smiley syntax in a code window:
Eric Wright
Message 3 of 11
broepke
Test signature
Brian Roepke
Director, Analytics & Insights
Message 4 of 11
Steve_Johnson
I see the "don't parse code for smileys" feature isn't working.
Steve Johnson - blog nauseam - ClassicArray
Message 5 of 11
wrighte
in reply to: Steve_Johnson
If you change emoticon type to 'none"  under My Settings-->Preferences,-->Display, the smileys won't  display.
Eric Wright
Message 6 of 11
Steve_Johnson
Yes, I know, but that's a global setting. It doesn't make sense to ever parse code for smileys or anything else, regardless of that setting. But that's a tiny nitpick among the terrible mess of this new forum software as a whole, so it's not worth worrying about.
Message 7 of 11
kdub_nz
I agree that Smileys should be exempted from code irrespective of global settings ...
.. re the nitpick: just tackle one nitpick at a time, eventually it may be suitable for you 🙂
If we aren't going to get our newsgroups back at least attempt to make this forum professional.
yeah, I know ,, that sounds like something from a fortune cookie  !
// Called Kerry in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect.
class keyThumper<T> : Lazy<T>;      another  Swamper
Message 8 of 11
kdub_nz
in reply to: kdub_nz
and in answer to a question this morning :
I DO know the code in my sig' is incorrect, but I can't use the correct characters in the signature box 😞
the sig' should read
class keyThumper <T>
Message 9 of 11
matt.smith
testing
Message 10 of 11
matt.smith
in reply to: matt.smith
testing again with more copy
Message 11 of 11
matt.smith
test reply
@wrighte wrote:
🙂  what does that do
