Hi
Can i overlay results in communicator? For ex: i want to overlay weld line result to temeperature @ flow front.
when i tried it ..compare,overlay and quantify options are disbaled in my communicator.
Solved by nordhb. Go to Solution.
you need to select Air traps or Weld lines plot first in Autodesk Simulation Moldflow Communicator.
The Overlay button then changes from grey to active.
Click the Overlay button, and select result you want to overlay on Air traps or Weld lines.
Hope this helps.
Berndt
for Compare, you need two studies in the .mfr file.
Before Publish > Results to MFR format , you need to select the two studies with results mark for export to be published.
Select first study, then Ctrl + LeftMouseButton for second study, then Publish > Results to MFR format to save to .mfr-file
Note: Only results files exported from Autodesk Simulation Moldflow Insight can be compared against criteria files using Quantify.
Berndt
Hi Mayur,
thank you for the suggestion.
A good idea, and I think you should raise it at the Simulation Moldflow Idea Station.
There is an online procedure in which you can directly raise enhancement requests/ideas for the Autodesk Simulation Moldflow products at the Simulation Moldflow Idea Station.
In Moldflow Adviser or Moldflow Communicator and tab Community, you have the button IdeaStation.
This links to Simulation Moldflow Idea Station
Here enhancement requests and ideas are posted, and users can vote by kudos.
The Simulation Moldflow IdeaStation is reviewed by Simulation Moldflow Development Team.
Review guidelines and best practices before posting a new idea.
Thank you.
Berndt
