Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Manual Calculations for Steel Design using API
8 REPLIES 8
Message 1 of 9
odysseasg
2687 Views, 8 Replies
I'm trying to design a steel section using VB. I guess the procedure is calling the IRDimCodeService interface and the ModalEditManualParams method. I can not seem to access the IRdimCodeService (IRDimClient.GetRDimCodeService) as i can't implement IRDimClient.
Can anyone help me with this?
8 REPLIES 8
Message 2 of 9
Rafal.Gaweda
in reply to: odysseasg
Hi
Take a look at attached pdf
Rafal Gaweda
Message 3 of 9
odysseasg
in reply to: Rafal.Gaweda
Hello Rafal,
Any ideas on how to access IRDimClient? Does it derive from IRDimServer? I cannot access it through RobotApplication.Kernel.GetExtension("RDimClient").
Odysseas
Message 4 of 9
Rafal.Gaweda
I have never gone that far with API 😞
I will do my best checking it.
Rafal Gaweda
Message 5 of 9
odysseasg
Thank you Rafal, I appreciate that.Looking forward to a solution to this.
Regards
Message 6 of 9
Rafal.Gaweda
IRDimClient - This interface is implemented by the external  COM codes (standards). It is not available in Robot.
With the help of COM interfaces you can not call any of the windows.
Rafal Gaweda
Message 7 of 9
odysseasg
So there's no way i can manually input Forces for the section design using the API (by accessing the dialog box shown in the attached file)?
Message 8 of 9
Rafal.Gaweda
No, not possible.
Forces should be imported from model.
Rafal Gaweda
Message 9 of 9
odysseasg
Ok, Thanks
