Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Coordinates of the nodes
13 REPLIES 13
Message 1 of 14
andrea_pontiggia
1209 Views, 13 Replies
In a model I have the coordinates of the nodes with values of type X  = 20.58888833  and Y=15.56559999.
The model is imported from Revit, why Revit fails to draw with a degree of accuracy of less? For example, X = 20.60 and Y = 15.55
Second question, in the same robot model if I run the automatic correction with precision = 0.01, after the model has the same coordinates.
You can correct the model automatically?
thanks
Andrea
13 REPLIES 13
Message 2 of 14
Use this utility:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Rounding-up-coordinates-API/m-p/3430533/high...
Rafal Gaweda
Message 3 of 14
Use correction
or Generate Model with correct precision
Rafal Gaweda
Message 4 of 14
The problem now is that the coating does not transmit the load. How do I fix this? thanks
Andrea
Message 5 of 14
Send us Revit model to check
Rafal Gaweda
Message 6 of 14
This is the Revit file: http://we.tl/7ylJ7MuqIN
Andrea
Message 7 of 14
Taka e look below at RST analytical model errors
Robot file with corrected geometry attached (my understanding how this should be done).anaerros.jpg
Rafal Gaweda
Message 8 of 14
Rafal.Gaweda
in reply to: Rafal.Gaweda
RST model correction
1. To unjoing wrongly connected columns from walls (marked on right hand sied on screen capture in previous post)
2. Walls can be corrected this way:
3. Beams
4 Braces : http://screencast.com/t/Sl1NhtJm
Corrected model  http://www.4shared.com/file/HGHEme1r/Edificio_21a_v031.html
Rafal Gaweda
Message 9 of 14
Thank you very much!!!!!
The video  to correct braces me to a feature of Revit did not know.
Andrea
Message 10 of 14
You may also drag this nodes but sometimes Align works faster and better.
Rafal Gaweda
Message 11 of 14
Hello!
I have a result file with the XYZ coordiantes of the nodes, like this:
Node # 9 ( X = 508.198, Y = 110.16, Z = -4052.31 )
    Displaced Position : X = 508.198, Y = 110.16, Z = -4052.31
    Displacement = DX: 0.000241976, DY: -0.000159354, DZ: -0.00506048, Magnitude: 0.00506877
     Current Result Value: 5.068766307e-003 mm
I would like to know the XYZ coordinatey more accurate, so in a form like this:
Node # 9 ( X = 508.198XXXXX, Y = 110.16YYYYYY, Z = -4052.31ZZZZZZ )
Is it possible to change this accuracy?
BR.
Message 12 of 14
Rafal.Gaweda
Left - for data, right for displacement results:
Rafal Gaweda
Message 13 of 14
Hello!
Sorry, I forgot to mention that I'm working in Multiphysics 2013.
Are these screenshots referring to it?
Message 14 of 14
Rafal.Gaweda
No, this is Robot forum.
Rafal Gaweda
