• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Product Support
    Rounding up coordinates (API)
    1211 Views, 34 Replies
    04-25-2012 08:35 AM
    I am attaching small addin (private, not ADSK) for rounding up coordinates in Robot
    You can add it to add-ins menu:
    - as dll (the fastest method of getting results from robot) basing on dll_1.zip from this thread starting from point 13
    http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Creating-DLL-for-API-and-making-it-available...
    - as exe
    or by running exe
    It seems to work OK.
    Rafal Gaweda
    Product Support
    Please use plain text.
    Active Contributor
    Re: Rounding up coordinates (API)
    04-25-2012 09:37 AM in reply to: RG_Adsk
    Does this add-in applies to node coordinates only or contour panel points are also included in the rounding up?
    Valued Contributor
    Rafacascudo
    04-25-2012 12:39 PM in reply to: sergey.churilov
    it will round up everything.
    igos
    07-31-2012 10:40 PM in reply to: RG_Adsk
    Hello, Rafal
    Thank you for the solution. Unfortunally, it doesn't work on my PC (not exe, nor dll). OS is Windows 7 x64, RSA 2013 SP1.
    I have obtained this error (please, see file error.png)
    Log of exe error in file LOG.txt
    If you need any additional info, please, let me know.
    Thank you in advance!
    Product Support
    08-01-2012 12:49 AM in reply to: igos
    Igor,
    Try this:
    Start Command Prompt as Admin (from rigth hand mouse menu) then unregister and register robot exe as decribed here:
    http://forums.autodesk.com/t5/Autodesk-Robot-Structural/VBA-Excel-macro-for-any-object-geometry-modi... - message 8/9
    Rafal Gaweda
    Product Support
    igos
    08-11-2012 10:41 PM in reply to: RG_Adsk
    Rafal, thanks a lot for your support!
    Valued Mentor
    tony.ridley
    08-12-2012 06:40 PM in reply to: igos
    Rafal,
    I have Robot 2012 and 2013 installed on my PC.  I installed your add in and it works OK on 2013, but when I try to use it on 2012 I get the following error......................
    Is this because the add in is already "registered" to 2013?
    Tony
    Product Support
    08-20-2012 02:32 AM in reply to: tony.ridley
    Can be. Please register v 2012
    (command line must be run in Admin mode: message 6 http://forums.autodesk.com/t5/Autodesk-Robot-Structural/API-error/m-p/3518984/highlight/true#M5791)
    Rafal Gaweda
    Product Support
    dc
    New Member
    09-13-2012 06:44 AM in reply to: RG_Adsk
    I downloaded the roundingup.zip nad run add-ins in robot , it listed on add-ins, but clicked it do not run.
    Mike
    Product Support
    09-13-2012 07:08 AM in reply to: dc
    Example movie: http://screencast.com/t/CFsS8hljU9Ik
    Sometimes click twice on Round Up button
    Rafal Gaweda
    Product Support
