please can any one aid me? i started revit architechture 2009 last year and just switched to revit structural 2013 i am lost, apart from walls me cant creat nothing.
Solved by AJA14. Go to Solution.
Hi.
What exactly do you mean by can't create nothing. If that means you can't model elements because you can't find them, then you need to install the families, family templates, and project templates from Autodesk website, then place them in the correct location. Otherwise, please clarify so that we may better assist you.
i can model elements well but the challenge i have is in detailing reinforcements. like i dont have any rebar shape family in my library...
Hi. Rebar shapes are families as well that exist in the library and you need to load them to into your project unless you start from a structural template that already has them. If you could provide a snapshot of what your doing, I might be able to figure out what the problem is.
Template file with what name are you using? let me confirm with mine or alternatively can you send it to me, please?
