I am using Autodesk Revit Structure 2011.
In one of my company's project, two drop beams (20x80cm each) & two hidden beams (120x32cm each) are intersecting in a column with each drop beam is perpendicular to each other. The hidden beam is also perpendicular to each other. Each drop beam is align with each hidden beam c/c.
I will draw each drop beam from one end of beam upto the column where those 4-beams are intersecting each other. Then I will draw each hidden beam from one end of beam upto the column where those 4-beam intersect. After drawing those hidden beam, the 2 drop beams will automatically extended upto the edge of hidden beam, making a short cantiliver within the half width of hidden beam.
When the Architect saw this short cantiliver, he told me to remove because he don't like those drop beam. I am trying to remove but I fail. Anybody can give me an advise how can I remove those?
